查看: 305|回复: 5
Navistar N13
 楼主| 发表于 2019-1-30 15:02:06 来自手机 | 显示全部楼层 |阅读模式
{"text":"so I am trying to make the jump to the owner op side of things and was thinking about purchasing an international. I was originally thinking on getting an ISX but was told that the rebranded N13 motor is a lot better than it was in the past. Was wondering what you alls take is on this? I kind of want to go ahead with it because my friend actually owns a mf13 and has had no problems out of it for the 8 months he's owned it so I figured the n13 should be even more reliable right?? The truck I'm looking at is a 2014 + eagle with the n13 and 400k miles. It's going to be diamond renewed as well.","pics":"[]","canComment":true}
发表于 2019-6-23 00:57:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"International is garbage, everything breaks a lot! And parts cost way more then any other trucks!","replyToPid":0}
发表于 2019-10-7 04:56:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"I love my international, my first had a cat and my second had a Cummins ISX 15 just got it last December and been playing catch up on the maintenance. just under 500k now and this year I've done the AC and two brake chambers. need to do the P.S. and coolant reservoir and level sensor all long term maintenance issues that where never done. if you can keep up with the maintenance I haven't had any serious issues the fuel pump was upgrade before i got it. but that was the only history I know of it","replyToPid":0}
发表于 2019-10-7 05:42:39 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"."}
发表于 2019-10-7 05:45:10 来自手机 | 显示全部楼层
791349 发表于 2019-10-06 20:56:36 I love my international, my first had a cat and my second had a Cummins ISX 15 just got it last December and been playing catch up on the maintenance. just under 500k now and this year I've done the AC and two brake chambers. need to do the P.S. and coolant reservoir and level sensor all long term maintenance issues that where never done. if you can keep up with the maintenance I haven't had any serious issues the fuel pump was upgrade before i got it. but that was the only history I know of it
","text":"sorry pal total garbage","replyToPid":222487}
发表于 2019-10-30 12:44:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"I got a 15 with the n13 it's pretty decent. couple issues with it being fuel efficient at 420k mi but no real issues I've seen. parts are alot expensive but just it's part of the business","replyToPid":0}
GMT+8, 2026-4-16 13:00 , Processed in 0.096083 second(s), 24 queries .
