查看: 112|回复: 2
n 14 celect plus idles uneven when warm
 楼主| 发表于 2019-1-30 10:47:58 来自手机 | 显示全部楼层 |阅读模式
{"text":"N 14 select plus runs fine for 5or6 minutes when cold. Then starts skipping and idleing up and down. Runs fine at road speed no skip. Any ideas?","pics":"[]","canComment":true}
发表于 2019-3-5 12:19:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"#5 injector possible, Great engine, 1,260,000 till I had to overhaul the motor, wished I still had it ","replyToPid":0}
发表于 2019-3-11 12:30:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have your oil tested and a Dyno. I had one and a valve head broke off at 290,000 and caused more damage in the first 2 min before I could shut the engine off.","replyToPid":0}
GMT+8, 2026-3-21 11:47 , Processed in 0.058863 second(s), 23 queries .
