查看: 112|回复: 2
Truck hard to start
 楼主| 发表于 2019-1-30 10:46:30 来自手机 | 显示全部楼层 |阅读模式
{"text":"Flood water came up to about 3/4 of frame i had seloinoid on starter repair. The truck will start occasionally with starter fluid it will run for awhile but if I turn on the cruise or fan switch it immediately kill. Any suggestions?","pics":"[]","canComment":true}
发表于 2019-3-26 02:57:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"How's the oil... Any water get into it?","replyToPid":0}
发表于 2019-3-26 03:04:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"get a can of silicone  spray and start spraying your electrical connections . I'd change all the filters and fluids too if it were my truck","replyToPid":0}
GMT+8, 2026-2-4 23:40 , Processed in 0.060834 second(s), 23 queries .
