查看: 141|回复: 2
Volvo beeper for following to close
 楼主| 发表于 2019-1-30 10:39:58 来自手机 | 显示全部楼层 |阅读模式
{"text":"I drive this 2017 Volvo it has the following distance i tell you i didnt think i tailgated others but this thing make me stay almost 2 truck and trailer lenghths back needless to say the stupid things always going off beeping\nIt also has the automatic braking that is a dangerous feature","pics":"[]","canComment":true}
发表于 2019-3-11 12:33:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have that on my 2019. You should be able to adjust the distance on the sensor. Read your hand book, if you don't have one, then call a dealer.","replyToPid":0}
发表于 2019-4-4 11:35:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"confirmed, older models the following distance can be adjusted in seconds, newer models it's a 3 bar adjustment, and obviously because it's a time-sensitive adjustment the faster you're going the larger your distance will be, also stop tailgating LOL","replyToPid":0}
GMT+8, 2026-3-21 10:08 , Processed in 0.084862 second(s), 23 queries .
