查看: 733|回复: 1
Cement, fly ash and those types, unloading. Top air?
 楼主| 发表于 2019-1-30 10:13:34 来自手机 | 显示全部楼层 |阅读模式
{"text":"Just wondering whats your method of unloading. Top air, no top air.\n\nI do bulk cement in the oilfield and i see a lot of guys like using a mix of top air and aerators not all the way open. Why? I never use top air except under a few circumstances. Aerators all the way open. Once i get up to 13-15 psi open pressure control about half way and slowly crack a bottle all the way open. Once cement is flowing slowly cut back pressure control so just enough air keeps the cement from plugging up. A good running trailer and short 10ft hose and 40k gone in 35 min or so","pics":"[]","canComment":true}
发表于 2019-4-1 12:23:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"I did the same thing never liked using top air","replyToPid":0}
GMT+8, 2026-2-4 09:25 , Processed in 0.069087 second(s), 23 queries .
