查看: 415|回复: 3
What is this light and why is it on!!!!
 楼主| 发表于 2019-1-29 19:18:28 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi, I currently work for a small company out of Chicago OTR. The owner is very poor at maintenance, I have been having this light pop up along with the check engine light and I don't know what it means. It seems to be more common when I have a heavy load, when it is on I cannot use cruise control. To make it go off usually I have to turn off the power switch and sit for 15 min or so but that doesn't always work. The boss always says it's nothing, well it's obviously something! I have a Freightliner cascadia evolution 2014 with 323,000 miles and it is an automatic. The light looks like a truck climbing a hill circled with a line through it exactly like the HSA OVRD switch picture but I push it and it doesn't take the light off. Any help is appreciated!","pics":"[]","canComment":true}
发表于 2019-3-26 11:23:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"being an automatic, I'm going out on a limb here and say that the hill start assist isn't working properly. automatics use an assisted 'hold' function while on a slope so you dont roll while moving your foot from one petal to the other. I would look more into that if you haven't already... super late reply but I hope it might help at least someone.","replyToPid":0}
发表于 2019-4-18 16:34:10 来自手机 | 显示全部楼层
584090 发表于 2019-03-26 03:23:20 being an automatic, I'm going out on a limb here and say that the hill start assist isn't working properly. automatics use an assisted 'hold' function while on a slope so you dont roll while moving your foot from one petal to the other. I would look more into that if you haven't already... super late reply but I hope it might help at least someone.
","text":"The Hill assist most drivers pull the fuse to it because its AAF. CHECK FUSES ON DIAGRAM. Im guilty of disabling it. If it is really broken only Freightliner has the Hardware to diagnose it and charge around 3k or more to replace it.","replyToPid":5802}
发表于 2019-5-19 10:59:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"This is correct, It is a hill climbing assist on automatic transmission This prevents the truck from rolling backwards, Do not disable this, It will cause your truck to roll back and probably cause an accident on the car behind you as, A lot of cars pull up really close behind Us. It is  And your Cruze  Controll will not work while it is activated but if a Check engine light comes on that is a separate problem. Hope it helps","replyToPid":0}
GMT+8, 2026-4-17 08:05 , Processed in 0.086514 second(s), 24 queries .
