查看: 614|回复: 5
I need to do my inspection soon (i live in PA) and these lights are on!
 楼主| 发表于 2019-6-12 12:22:42 来自手机 | 显示全部楼层 |阅读模式
{"text":"What does these codes mean? the truck drives fine, detroit DD15 2014 cascadia evolution.. 556,847 Miles on it. like i have no clue why does these lights remain on all the time... i'm an o/o and no need crazy expensive repairs right now. please any help?","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0},{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0},{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0}]","canComment":true}
发表于 2021-7-25 05:53:35 来自手机 | 显示全部楼层
957369 发表于 2021-07-24 21:25:55 Ado the inspection yourself. But go have the codes pulled. Mostly likely a abd sensor they are cheap and easy to fix half the time they just need the brake dust and road grime cleaned off .
","text":"This is a 2 year old post. That code is for the (DEF) aftertreatment system. ","replyToPid":437432}
发表于 2019-6-12 21:59:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"you need to get the computer hooked to it and see what's going on","replyToPid":0}
发表于 2019-6-12 13:57:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Google","replyToPid":0}
发表于 2019-6-12 13:50:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"looks like Christmas. pull in and get checked out.","replyToPid":0}
发表于 2021-7-25 05:25:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ado the inspection yourself. But go have the codes pulled. Mostly likely a abd sensor they are cheap and easy to fix half the time they just need the brake dust and road grime cleaned off . ","replyToPid":0}
GMT+8, 2026-4-17 07:54 , Processed in 0.116307 second(s), 24 queries .
