查看: 295|回复: 18
I could use some advice
 楼主| 发表于 2019-6-12 07:49:26 来自手机 | 显示全部楼层 |阅读模式
{"text":"So I am on I-70 in Colorado west of Denver right before 40W. I am headed to Walden co. has anyone driven 40 West?  its Exit 232 off of 70. ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-6-12 09:29:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would go on over the mountain to silverthorn.  And up Co 9 to kremling then up to Walden.  It a lot better road.  I have been both ways. It will be a good deal faster as well","replyToPid":0}
发表于 2019-6-12 22:43:43 来自手机 | 显示全部楼层
710313 发表于 2019-06-12 14:32:22 No worries... just use some sense, don’t rush, enjoy scenery.... not everyone gets to travel some of these roads
","text":"I agree, probably really pretty this time of year. Plus not as much traffic as in the winter since all the ski resorts are closed.","replyToPid":65242}
发表于 2019-6-12 09:41:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"going through there is stressful man, especially at night .  last time I did it a few months ago , it was starting to snow and I was afraid I was gonna slide off the mountain.  I don't run Colorado anymore takes 7 hrs to drive 200 miles","replyToPid":0}
发表于 2019-6-12 09:32:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Exit 205. ","replyToPid":0}
发表于 2019-6-12 09:54:20 来自手机 | 显示全部楼层
415632 发表于 2019-06-12 01:51:24 Well if you go over to exit 205 it's a lot flatter. And you cross Eisenhower on 70 instead of 40.
","text":"And when you go thru the tunnel and start down exit 205 is at the bottom of the grade. So take it easy from the top.  Or you will get your brakes hot getting off at 205.  Just sayin. ","replyToPid":64400}
发表于 2019-6-12 09:41:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"I saw the new drivers question didn't know what his mountain exp. would be. ","replyToPid":0}
 楼主| 发表于 2019-6-12 08:51:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"thank you!","replyToPid":0}
 楼主| 发表于 2019-6-12 09:34:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"thank you for the advice I truly appreciate it","replyToPid":0}
 楼主| 发表于 2019-6-12 09:39:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"🤣","replyToPid":0}
发表于 2019-6-12 09:40:33 来自手机 | 显示全部楼层
710313 发表于 2019-06-12 01:38:12 Like my description of the switchbacks on 40.... lol
","text":"Yes sir.  Like crossing Hoover dam before they built the new bridge. Couldn't pass the truck in front of you cause it was you. ","replyToPid":64376}
发表于 2019-6-12 09:44:05 来自手机 | 显示全部楼层
710313 发表于 2019-06-12 01:43:17 Yup..... hell, 40 can be interesting for any driver...
","text":"Yes it can","replyToPid":64389}
GMT+8, 2026-4-18 14:26 , Processed in 0.102725 second(s), 24 queries .
