查看: 97|回复: 0
Brake pedal extremely stiff
 楼主| 发表于 2019-1-29 18:10:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"Ok, I'm just a driver, not a mechanic but our \"mechanics\" have never been able to diagnose and fix this problem.\nI drive a 97 FLD120. The brake pedal is very stiff, like these is too much air in in the system. It has the correct amount though, about 120 psi. There is about 1/4\" of \"play\" until you press too hard and the wheels will lock up and nosedive to the right. They said they changed everything that could be changed but the problem still exists. This is a safety issue that they don't have to drive on a daily basis. Can someone give me a direction to go in please.....","pics":"[]","canComment":true}
GMT+8, 2026-3-21 05:17 , Processed in 0.076578 second(s), 23 queries .
