查看: 150|回复: 0
Cummins ISX pushing out coolant
 楼主| 发表于 2019-1-28 21:18:55 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have a 2012 Kenworth 660 with a 2250 engine it it. The truck has 1 million miles on it and to this point has been very reliable. I did an oil change recently and had the crankcase filter changed and the tech informed me that the filter in the crankcase had moisture inside. About a week later I got a check engine light and took the truck to my mechanic. Mechanic said that engine was building too much pressure. He replaced the crankcase sensor, crankcase filter and the truck ran good for about two weeks. At this point, I started to lose coolant. I called my mechanic and he told me to let the engine cool down and start the truck with the radiator cap off. The radiator pushed all of the coolant out even though the cap was off and the engine was cold. Coolant was pushed out within 30 seconds. I was in the middle of nowhere when this happened. My mechanic told me that most likely it was the air compressor because the truck was running fine. I drove the truck to his shop and added coolant every 70 miles or so. The temperature ran at 180 degrees and the oil temp was normal and the mpg was average. The truck ran as if nothing was wrong. My mechanic checked the turbo first. He then dropped the coolant and isolated the air compressor but this did not relieve the pressure in the coolant system. The truck is running smooth and temperature and mpg are normal. Apart from pushing out the coolant, you would not know anything was wrong. There are no codes and there is no coolant in the oil and no oil in the coolant. I NEED HELP AND AM THANKING YOU IN ADVANCE FOR ANY SUGGESTIONS. My mechanic wants to remove the injectors and replace the six injector sleeves.","pics":"[]","canComment":true}
GMT+8, 2026-3-21 06:08 , Processed in 0.068559 second(s), 24 queries .
