查看: 76|回复: 5
trucker path issues
 楼主| 发表于 2025-11-9 02:24:29 来自手机 | 显示全部楼层 |阅读模式
{"text":"Anyone else having trouble with Trucker Path freezing up? I've updated it, uninstalled, reinstalled. it goes along pretty good for a while, then locks up! the other day it did it in a city where we needed it the most! I'm frustrated that I'm paying for something that doesn't work half the time! We're about to scrap it for a $900 Garmin that should work better!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2025-11-10 23:18:07 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I don't need GPS to drive. maybe you should go back to McDonald's"}
回复 支持 4 反对 2
发表于 2025-11-9 07:11:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"My Atlas always works guaranteed.  Never fails. Only costs me 39$ for new one. 🤣","replyToPid":0}
回复 支持 2 反对 2
发表于 2025-11-9 06:57:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"i been having issues with mine to sometimes like lot of times it doesn't take off when the truck takes off it does what it wants to seems like","replyToPid":0}
发表于 2025-11-9 04:28:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m having the same troubles … it doesn’t reroute when you miss your turn until you’re miles passed your turn","replyToPid":0}
发表于 2025-12-3 08:00:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've had that happen and found out I didn't have enough megabytes to run it through the carrier I had. To fix it, I just changed my plan to unlimited and now it works fine.","replyToPid":0}
GMT+8, 2026-3-21 18:04 , Processed in 0.096352 second(s), 24 queries .
