查看: 28|回复: 6
CB Radio
 楼主| 发表于 2025-10-12 11:33:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"How do you use the CB Radio , been trying to talk , say something but cant. I press talk and just shuts down","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2025-10-15 12:27:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hey man not to be rude or nothing but buy a real cb for a couple hundred bucks you could get a nice set up don’t need noting fancy just a cobra 29 peaked and tuned by a cb shop with a good antenna will work","replyToPid":0}
发表于 2025-10-12 18:45:08 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I don’t think it’s going to last truthfully. I’m surprised it’s still up tbh. I think they were giving it a test run to see if people would actually use it, assuming that people that use traditional cb radios (I don’t) would get more into the digital era. I did try to use it when it first launched. I found one experience so far, but that’s only because the dummy had the button pressed down by accident and didn’t know he had it pushed. \n\n\nCompletely off topic, but Perhaps “they” (the elitists) want to listen to what we are saying through digital means? It won’t be the first time they do these monstrosities; the fbi and cia spy on everybody all the time"}
发表于 2025-10-16 08:09:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"just you just push the button to talk and then push it again to stop and then push the red power button to take it away","replyToPid":0}
发表于 2025-10-16 08:09:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"push the three lines I think the three dots whatever to change stations and so on","replyToPid":0}
发表于 2025-10-15 20:52:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"I been trying to figure that as well","replyToPid":0}
发表于 2025-10-16 08:08:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"this unit is the loudest best cb than anything I've ever heard!","replyToPid":0}
GMT+8, 2026-2-4 12:15 , Processed in 0.076831 second(s), 24 queries .
