查看: 236|回复: 9
Is this normal oil temp ?
 楼主| 发表于 2019-6-11 07:54:07 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1344.0,\"name\":\"\",\"url\":\"\",\"width\":756.0}]","canComment":true}
发表于 2019-6-11 08:38:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes if it's a Cummins ISX and you are pulling pretty hard ","replyToPid":0}
发表于 2019-6-11 08:40:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Water temps up a little too","replyToPid":0}
发表于 2019-6-11 08:46:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Isx normal, water 210 220","replyToPid":0}
发表于 2019-6-11 08:50:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yup normal as my truck sits there also","replyToPid":0}
发表于 2019-6-11 08:53:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes if it is an ISX Cummins it's normal I bout **** when I seen it that high the first day I got this new truck it has a I s x ..last truck was a glider with 6 nz cat ..30 + yrs of truckin ide never seen oil temp so high except when oil cooler on big cam 3 went bad and she was melting down. I hope that  this gives you piece of mind..be safe brother trucker","replyToPid":0}
发表于 2019-6-11 08:58:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"I hear ya, mine runs 190, 200 unless I’m pulling a long or steep grade 🤷‍♂️","replyToPid":0}
发表于 2019-6-11 09:17:33 来自手机 | 显示全部楼层
682867 发表于 2019-06-11 00:58:28 I hear ya, mine runs 190, 200 unless I’m pulling a long or steep grade 🤷‍♂️
","text":"Yea mine runs 190. I start pullin it comes up to about 200 205. And oil will come up to 230ish and oil pressure down to about 32","replyToPid":63048}
发表于 2019-6-11 09:18:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"My prostar is running 225°F right now ","replyToPid":0}
 楼主| 发表于 2019-6-11 09:58:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks everyone ","replyToPid":0}
GMT+8, 2026-4-18 12:47 , Processed in 0.091243 second(s), 24 queries .
