查看: 199|回复: 10
Brake Check
 楼主| 发表于 2025-8-20 08:18:43 来自手机 | 显示全部楼层 |阅读模式
{"text":"cops will be hot on us starting August 23 so make sure your breaks on truck and trailer are good","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
1万
发表于 2025-8-20 16:50:38 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I think you mean\"Brakes\" not \"breaks\"\n\"Brakes\" and \"breaks\" are different words with distinct meanings, despite sharing the same pronunciation. \"Brakes\" refers to the mechanism that slows or stops a vehicle, while \"breaks\" can refer to periods of rest, actions that cause something to separate, or even the plural of \"break\". \nHere's a breakdown: \nBrakes:\nThis word is a noun and refers to the device used to slow down or stop a vehicle, like the \"brakes\" on a car. \nBreaks:\nThis word can be a noun (as in \"take a break\") or a verb (as in \"to break something\"). It can also be the plural of \"break,\" referring to multiple instances of something being separated or interrupted. \nExamples: \n\"The driver slammed on the brakes to avoid hitting the deer.\"\n\"I need a break from work.\"\n\"The vase broke when it fell.\"\n\"There are several breaks in the road due to the construction.\" \n👍 🇺🇸 🙂"}
发表于 2025-8-20 23:39:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Okay...thank you for the short English lesson, Mr. Freeze.\nThanks for the heads up, Chaparrito. I will keep my breaks in check.","replyToPid":0}
发表于 2025-9-29 04:38:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don’t usually take a break in my trailer because it usually has a seal on it.","replyToPid":0}
1万
发表于 2025-8-21 16:48:30 来自手机 | 显示全部楼层
2457713 发表于 2025-08-21 00:57:58 Damnm...you had to write a book on this? 😂
","text":"I just copied and pasted it from my phone...\n🙂 🇺🇸 👍\n\nnothing wrong with learning to speak and spell English","replyToPid":486695}
发表于 2025-8-21 08:57:58 来自手机 | 显示全部楼层
1031233 发表于 2025-08-20 08:50:38 I think you mean\"Brakes\" not \"breaks\"\n\"Brakes\" and \"breaks\" are different words with distinct meanings, despite sharing the same pronunciation. \"Brakes\" refers to the mechanism that slows or stops a vehicle, while \"breaks\" can refer to periods of rest, actions that cause something to separate, or even the plural of \"break\". \nHere's a breakdown: \nBrakes:\nThis word is a noun and refers to the device used to slow down or stop a vehicle, like the \"brakes\" on a car. \nBreaks:\nThis word can be a noun (as in \"take a break\") or a verb (as in \"to break something\"). It can also be the plural of \"break,\" referring to multiple instances of something being separated or interrupted. \nExamples: \n\"The driver slammed on the brakes to avoid hitting the deer.\"\n\"I need a break from work.\"\n\"The vase broke when it fell.\"\n\"There are several breaks in the road due to the construction.\" \n👍 🇺🇸 🙂
","text":"Damnm...you had to write a book on this? 😂","replyToPid":486673}
 楼主| 发表于 2025-8-21 07:23:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"you and your punk azz company","replyToPid":0}
 楼主| 发表于 2025-8-21 07:23:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"simon warner","replyToPid":0}
 楼主| 发表于 2025-8-21 07:24:24 来自手机 | 显示全部楼层
","text":"hahaha","replyToPid":486673}
 楼主| 发表于 2025-8-21 07:25:22 来自手机 | 显示全部楼层
2677128 发表于 2025-08-20 15:39:40 Okay...thank you for the short English lesson, Mr. Freeze.\nThanks for the heads up, Chaparrito. I will keep my breaks in check.
","text":"hahaha you're very funny you made me laugh so much 😆 you little clown 🤡","replyToPid":486681}
GMT+8, 2026-3-21 03:06 , Processed in 0.098636 second(s), 25 queries .
