查看: 88|回复: 7
Melting cargo straps?!
 楼主| 发表于 2025-8-13 04:29:42 来自手机 | 显示全部楼层 |阅读模式
{"text":"I had to replace several brands new cargo straps. They had damage along a diagonal line that looked like someone touched a hot knife to them.\n\nAnyone ever seen anything like that? The only thing I can think of is I now have an aluminum flarbed and the aluminum may have gotten hot enough when I went out to Navada to melt the straps where the came into contact with it.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2025-8-13 04:36:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have seen before.  it comes from heat and contact with metal","replyToPid":0}
发表于 2025-8-13 04:32:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Are the straps behind the bump rail?","replyToPid":0}
发表于 2025-8-13 06:26:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Were you hauling copper?","replyToPid":0}
 楼主| 发表于 2025-8-14 08:10:09 来自手机 | 显示全部楼层
990550 发表于 2025-08-12 22:26:06 Were you hauling copper?
","text":"@HighwayCowboy not hauling copper. Hauling cargo containers with steel edges and fiberglass walls.","replyToPid":486444}
 楼主| 发表于 2025-8-14 08:13:33 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"@GatorMcLusky the trailer doesn't have a bump rail. Its an aluminum deck Fontaine with holes near the edge of the deck for straps. The straps all went thru the holes and the hook is around the bottom edge of the deck."}
 楼主| 发表于 2025-8-14 19:09:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"@GatorMcLusky the trailer doesn't have a bump rail. Its an aluminum deck Fontaine with holes near the edge of the deck for straps. The straps all went thru the holes and the hook is around the bottom edge of the deck.\n(confounded autocorrupt)","replyToPid":0}
发表于 2025-8-17 07:39:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've had this happen but it looked like heat chaffing on mine. like a black melted band across from side to side. I quit using those afterwards","replyToPid":0}
GMT+8, 2026-3-20 23:32 , Processed in 0.066271 second(s), 24 queries .
