查看: 34|回复: 7
Truck Stops Full
 楼主| 发表于 2025-8-1 00:13:32 来自手机 | 显示全部楼层 |阅读模式
{"text":"Maybe it’s just the areas of the country I have been in lately, but it seems like most of the truck stops are packed full almost all day long. I stopped at a sizable Loves in Arkansas a few days ago and at 2:30 only 4 spots were left. Is freight really that bad?  Does anyone drive anymore?  What’s the deal?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2025-8-1 02:42:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes, rates never really recovered from high of 2021 (prices they should be at). Unless you have good dedicated contracts them your still doing ok.\nDepends on the truckstop. If they have around the clock deliverys truck stops close by are always full. Lots of times, people who live near truck stops use them as personal parking lots.","replyToPid":0}
回复 支持 3 反对 3
发表于 2025-8-6 22:04:32 来自手机 | 显示全部楼层
2716774 发表于 2025-08-06 13:47:34 As per Walmart policy, EVERY Walmart has to allow overnight parking. If they try and argue tell them to go read their policies again.
","text":"That simply is not correct. Allowing overnight truck parking is up to each individual store manager. Whether there are municipal regulations barring truck parking in the lot. Also, if  Walmart does not own the land the store is situated on the property owner may not allow overnight parking. It is always best to call ahead and check that stores parking policy. Walmart does not have a \"nationwide policy\" requiring overnight parking","replyToPid":486325}
发表于 2025-8-7 22:01:29 来自手机 | 显示全部楼层
925557 发表于 2025-08-06 14:04:32 That simply is not correct. Allowing overnight truck parking is up to each individual store manager. Whether there are municipal regulations barring truck parking in the lot. Also, if  Walmart does not own the land the store is situated on the property owner may not allow overnight parking. It is always best to call ahead and check that stores parking policy. Walmart does not have a \"nationwide policy\" requiring overnight parking
","text":"They used to have truck parking at the Walmart in Smelterville ID, from what i was told, because truck drivers were leaving their trash everywhere, and from another person, they said the manager was a C U N T and didn't like semis. i use to stop there every time i head home but can't do that anymore","replyToPid":486326}
发表于 2025-8-1 04:37:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you're in a rural area try the Walmart lot. pretty peaceful and food is much cheaper than a truck stop. check on truckerpath to make sure they allow parking though","replyToPid":0}
发表于 2025-8-6 21:47:34 来自手机 | 显示全部楼层
2760691 发表于 2025-07-31 20:37:43 if you're in a rural area try the Walmart lot. pretty peaceful and food is much cheaper than a truck stop. check on truckerpath to make sure they allow parking though
","text":"As per Walmart policy, EVERY Walmart has to allow overnight parking. If they try and argue tell them to go read their policies again.","replyToPid":486226}
发表于 2025-8-1 05:59:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"That is TX auto parts lane..expect on/off ramps even full by 6pm","replyToPid":0}
发表于 2025-8-7 07:43:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Interesting as the previous Walmarts that I worked at years ago had a specific policy stating that overnight parking was allowed\n\nLearn something new everyday as they say","replyToPid":0}
GMT+8, 2026-2-4 17:11 , Processed in 0.077897 second(s), 24 queries .
