查看: 23|回复: 2
trucker path GPS
 楼主| 发表于 2025-7-25 07:37:29 来自手机 | 显示全部楼层 |阅读模式
{"text":"want to get lost in Montreal? use the Truckerpath GPS... it really sent me down a rabbit hole.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2025-7-27 07:00:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you want to get the rabbit out of the l.o.g. you have to make a commotion like a d.o.g.","replyToPid":0}
发表于 2025-7-26 23:16:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Always have to double check your route. Can’t just rely on one app, check your truck gps as well as a physical map.\n\nTrucker Path needs quite a few updates for Canada. It does not show a lot of the key information like it does in the states.","replyToPid":0}
GMT+8, 2026-2-5 01:27 , Processed in 0.102859 second(s), 24 queries .
