查看: 49|回复: 12
Super Trucker
 楼主| 发表于 2025-7-25 05:52:55 来自手机 | 显示全部楼层 |阅读模式
{"text":"this is the same kind of dumb driver that gets 5 ft behind you in the middle lane get out of my way get out of my way. it's also the same kind of douchebag that's spends 30 minutes in the fuel lane","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2572.0,\"name\":\"\",\"url\":\"\",\"width\":1584.0}]","canComment":true,"externalShare":false}
发表于 2025-7-27 05:39:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"what's the back story here, what happened?","replyToPid":0}
发表于 2025-7-28 05:43:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"one of those shoulder low clearance bridges, he got no damage on driver side also left trailer door still good.","replyToPid":0}
1万
发表于 2025-7-28 03:18:21 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"it is obvious that he ripped it off on a low bridge, if it was a heavy load the trailer would be on the ground because of the weight...\n🙂 🇺🇸 👍\n\nyou can see the roof torn up and the rear doors pulled out at the top..."}
发表于 2025-7-27 06:57:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"How? oh, I see the 5 drivers there. we know how.","replyToPid":0}
发表于 2025-7-30 11:14:17 来自手机 | 显示全部楼层
1031233 发表于 2025-07-27 19:18:21 it is obvious that he ripped it off on a low bridge, if it was a heavy load the trailer would be on the ground because of the weight...\n🙂 🇺🇸 👍\n\nyou can see the roof torn up and the rear doors pulled out at the top...
","text":"Yes true enough","replyToPid":486146}
1万
发表于 2025-8-8 02:04:52 来自手机 | 显示全部楼层
1077505 发表于 2025-08-07 14:05:07 What does that have to do with the trailer buckling?
","text":"there is no frame under a van trailer, if you rip off the roof there is nothing to hold it up and together...\n🙂 🇺🇸 👍\n\nI've seen plenty over the years...","replyToPid":486335}
发表于 2025-7-28 15:07:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"yep n there's plenty more just like him","replyToPid":0}
发表于 2025-7-28 01:49:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Going 65mph into the ditch will do that also","replyToPid":0}
发表于 2025-7-28 00:11:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Seems to me , a heavy item /object with not enough weight distribution. \nSo trailer couldn’t handle it at that certain point 🤔","replyToPid":0}
发表于 2025-7-28 18:49:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"The other day I saw a truck leaning to the left like it was gonna tip over probably the paper bales but pull over at that point","replyToPid":0}
GMT+8, 2026-2-4 14:16 , Processed in 0.055800 second(s), 25 queries .
