查看: 68|回复: 7
memory usage
 楼主| 发表于 2025-6-19 22:52:14 来自手机 | 显示全部楼层 |阅读模式
{"text":"I use a Samsung S9 tablet on my dash,  why does TRUCKER PATH use so much memory?  While using it other apps like YouTube sound app choppy and run sluggish, streaming music or a podcast it skips and sounds choppy in general, even if using only trucker path the navigation voice is choppy sometimes, it will kind of freeze for a second then catch up sometimes, if I don't use a certain USB cable in the correct spot in the USB port in the power outlet then my tablet will actually loose charge, sometimes the tablet will switch to power saving mode because it says that trucker path is using so much memory the tablet is running hot and overheating. This ONLY happens while using trucker path, no other apps do that,  even if running only trucker path, I may have to uninstall and get a new Garmin like I planned originally","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2025-6-20 01:15:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't know. I have never used this app ever before.","replyToPid":0}
发表于 2025-7-3 21:29:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"my trucker path kills my battery even when its hooked to the charger. soon as I'm done running for the week, I make sure I log out","replyToPid":0}
1万
发表于 2025-6-30 01:48:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's probably spying on you...\nyou have a lot of information that they need to know...\n🙂 🇺🇸 👍","replyToPid":0}
发表于 2025-6-21 14:58:29 来自手机
2672741 发表于 2025-06-19 17:15:23 I don't know. I have never used this app ever before.
","text":"https://www.aa.org/","replyToPid":485275}
支持 0 反对 1
61
发表于 2025-6-20 06:00:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a Samsung A9, don’t know what the difference is between yours and mine. But this probably isn’t going to help you at all, but what I normally do is have trucker path on my phone, get the address off the app, and then pop it into my tablet (I use my tablet for navigation, it hasn’t let me down yet, and I’m very cautious while using it, different topic matter any way).","replyToPid":0}
发表于 2025-6-20 05:57:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Test","replyToPid":0}
发表于 2025-6-24 23:41:41 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I don't have this problem with mine. You have good LTE when you get the choppy sound right?\n\nCheck Trucker Path app's permissions. Mine is set to only allow location and only when the app is running.\n\nYou can also try turning on data saver for Trucker Path. That will throttle its memory usage somewhat."}
发表于 2025-6-29 23:45:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Your device is likely overheating, because Trucker Path is keeping your screen on, the device is constantly charging/on, plus where you have it positioned, it's likely absorbing a bunch of solar gain heat.  Try mounting it where it's not in the sun, and ideally, where it catches some air.","replyToPid":0}
GMT+8, 2026-3-21 03:35 , Processed in 0.140448 second(s), 24 queries .
