查看: 64|回复: 5
Low underpass
 楼主| 发表于 2025-6-11 04:25:32 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm new to this app. Does it tell you or route you around low underpass's","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2025-6-16 07:59:45 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"As long as your have set your actual truck profile it should route you around overhead clearances that are too low for you. **DON'T FORGET YOUR STACKS!!**  Also there is a selection you can select for the map to show all the heights for the overheads along your route. 😁😁"}
发表于 2025-6-11 07:56:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes but be on lookout especially in residential areas","replyToPid":0}
发表于 2025-6-11 11:38:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"About 90% of the time as long as you put in your truck settings right. Always be aware though","replyToPid":0}
发表于 2025-6-14 03:43:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"and use Google Street view in the area your concerned about...takes a few minutes but well worth it","replyToPid":0}
发表于 2025-6-21 07:25:31 来自手机 | 显示全部楼层
207357 发表于 2025-06-13 19:43:10 and use Google Street view in the area your concerned about...takes a few minutes but well worth it
","text":"Oh yes… this… “when in doubt, streetview.”","replyToPid":485140}
GMT+8, 2026-3-21 04:17 , Processed in 0.143169 second(s), 24 queries .
