查看: 60|回复: 21
Am I unhireable?
 楼主| 发表于 2025-6-5 14:14:50 来自手机 | 显示全部楼层 |阅读模式
{"text":"Been driving 4 months. Had 2 preventable accidents 1 in a truck stop. Blind side turn hit a truck with trailer. Other hit construction sign with blind side making a turn. \n\nAm I screwed now?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
1万
发表于 2025-6-5 16:57:19 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"are you still working ???\nit's a learning process, you will make mistakes... \n#1 learn from your mistakes and try not to make the same mistakes...\n#2 don't rush in tight spots, if you have to get out and look. \n#3 don't let others rush you, like your dispatcher. \n👍 🇺🇸 🙂"}
回复 支持 7 反对 0
 楼主| 发表于 2025-6-6 04:20:05 来自手机 | 显示全部楼层
1031233 发表于 2025-06-05 08:57:19 are you still working ???\nit's a learning process, you will make mistakes... \n#1 learn from your mistakes and try not to make the same mistakes...\n#2 don't rush in tight spots, if you have to get out and look. \n#3 don't let others rush you, like your dispatcher. \n👍 🇺🇸 🙂
","text":"Yes still working and getting loads. Talk to safety tomorrow. Trying to be extra careful and not make the same mistake again","replyToPid":484997}
发表于 2025-6-5 17:15:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Depends check on your mvr report sometime it will be reported some time it won't .... but 3 years should clear up everything buddy just thug it out for three year. Just don't get a dui","replyToPid":0}
发表于 2025-6-6 19:56:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"your good, as long as you keep it clean, or get good at C.Y.A. We all male mistakes starting out, the difference between people who make it and don't is work eithic and knowing when to keep quiet or not to.","replyToPid":0}
发表于 2025-6-7 01:19:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"keep doing that kind of driving you will be soon enough!","replyToPid":0}
发表于 2025-6-10 10:57:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Honestly,  driving the truck is probably 10% of trucking, another 20% is applying the training,  while 70% is mental, mental compactly, mentally thinking for other drivers on the road when you see them about to do something foolish.  I I'm approaching my fourth month now, but I'm a good driver because I'm a good responsible thinker...if you did all of that, and then asking that question,  maybe it's safer for you to not be on the road.","replyToPid":0}
发表于 2025-7-8 10:05:01 来自手机 | 显示全部楼层
2644704 发表于 2025-06-05 11:16:40 How do I check my mrv report?\n\nI don’t drink so not getting a dui should be easy.
","text":"Have you ever used GOOGLE?","replyToPid":484999}
发表于 2025-6-11 04:00:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"when in doubt.. stop, get out, and look 1st.  if at a truck stop and are unsure.. ask for help, most of us would gladly assist you vs. getting hit   the fact you care enough to ask for help is a good start, dont be in a hurry to wreck. gl 2 you","replyToPid":0}
 楼主| 发表于 2025-6-6 04:18:28 来自手机 | 显示全部楼层
2468200 发表于 2025-06-05 13:41:36 How could you not know how to get MVR??? That's part of driving
","text":"Had to look it up. Then I remember being told about it in cdl class. I just didn’t remember","replyToPid":485001}
 楼主| 发表于 2025-6-6 04:16:57 来自手机 | 显示全部楼层
1031233 发表于 2025-06-05 12:14:57 are you still working driving a commercial vehicle ??? \nyes or no \n🙂 🇺🇸 👍
","text":"Yes. Have to talk with safety tomorrow","replyToPid":485000}
 楼主| 发表于 2025-6-5 19:16:40 来自手机 | 显示全部楼层
2510596 发表于 2025-06-05 09:15:21 Depends check on your mvr report sometime it will be reported some time it won't .... but 3 years should clear up everything buddy just thug it out for three year. Just don't get a dui
","text":"How do I check my mrv report?\n\nI don’t drink so not getting a dui should be easy.","replyToPid":484998}
1万
发表于 2025-6-5 20:14:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"are you still working driving a commercial vehicle ??? \nyes or no \n🙂 🇺🇸 👍","replyToPid":0}
发表于 2025-6-5 21:41:36 来自手机 | 显示全部楼层
","text":"How could you not know how to get MVR??? That's part of driving","replyToPid":484999}
GMT+8, 2026-2-4 13:43 , Processed in 0.063784 second(s), 24 queries .
