查看: 31|回复: 4
Does this app have TDG routes for city of Edmonton or Alberta? Please guide !
 楼主| 发表于 2025-6-2 06:52:49 来自手机 | 显示全部楼层 |阅读模式
发表于 2025-6-2 20:04:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"If TDG route is the Canadian equivalent of a hazardous material route then I don't think so. \n\nI don't think the app has US hazardous routes either.","replyToPid":0}
发表于 2025-6-3 12:01:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't think you will find TDG route on any map. Just don't go near the tunnels and downtowns.","replyToPid":0}
发表于 2025-6-4 05:59:09 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"The app “Hammer” does. Not sure if it works, haven’t used it\n\nEdited to add you can add hazmat on the routing just before you hit start you can edit your truck and select which hazmat apply to you. \n\nWhen you have your route almost ready to go, on the botttom it says “trip settings” tap this, at the bottom you can adjust the truck settings.\n\nAgain, I haven’t tried it with this app but I’d rather trucker path over hammer navigation"}
发表于 2025-6-11 04:02:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use hammer to route for hazmat or od loads personally.","replyToPid":0}
GMT+8, 2026-2-4 14:08 , Processed in 0.062165 second(s), 23 queries .
