查看: 55|回复: 9
Moving from Bed Sty in Brooklyn NYC, heading to New Orleans, La. I’m in a 26’ Penske Truck.
 楼主| 发表于 2025-5-26 04:16:11 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can I take the Holland Tunnel through to Allentown Pa.? I’m seeing it’s shorter and misses Atlanta Ga. \nPlease give me some thoughts. I have to stop (sleep/rest) because I’m the only person who can drive it.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2025-5-27 08:03:08 来自手机 | 显示全部楼层
981973 发表于 2025-05-26 23:06:13 Yeah dude seriously be careful there was a driver on here that posted something about running into a bridge not to far from the holland tunnel that morons truck was 13’6 and the bridge he took out was 12’9 nyc is dangerous and not meant for tall trucks
","text":"I personally wouldn't believe any advice from you. Till you figure out what reality your living in","replyToPid":484853}
回复 支持 5 反对 1
发表于 2025-5-26 08:18:33 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"penske truck is 13'6\" height. Holland tunnel is 12'6\". Take GW. then cut back down to 78 to 81 to 40 to 75 to 59. Hope you make it. Report back here."}
发表于 2025-5-27 08:01:13 来自手机 | 显示全部楼层
","text":"you sure that wasn't YOU?? 🤔","replyToPid":484853}
发表于 2025-5-29 07:26:46 来自手机 | 显示全部楼层
665190 发表于 2025-05-28 21:57:01 NYC bridge heights are garbage. A posted NYC bridge height of 12'9\" should be easily accommodated5 a 13'6\" truck.\n\nI think the preferred route in/out, Throggs Neck, posted bridge heights at least that low.
","text":"many many years ago. I had customer in Bronx.  I seen sign 12 ft 9 ahead.  I darted off on next exit. boy that was mistake. I like to never navigate city streets. I told customer about that. He told me. that number is for winter when snow packed on road. I don't know if true.  I ripped anything in NE out of my map","replyToPid":484884}
发表于 2025-5-28 08:45:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"It's been 2 days. Did you make it?","replyToPid":0}
发表于 2025-5-27 07:06:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yeah dude seriously be careful there was a driver on here that posted something about running into a bridge not to far from the holland tunnel that morons truck was 13’6 and the bridge he took out was 12’9 nyc is dangerous and not meant for tall trucks","replyToPid":0}
发表于 2025-5-29 20:03:58 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"@mikey I hadn't heard the snow pack idea but it had to be as much garbage as the \"they measure height from the axle\" story I heard. The posted heights are are often several FEET shorter than what they should be. Snow doesn't get that deep in NYC. The idea of measurements from axle height makes even less sense."}
发表于 2025-5-28 20:47:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you live and drive a truck in NYC you should know the bridge heights in NYC are garbage. Stick to known routes like Throggs Neck to get in/out of that festering garbage heap of City.","replyToPid":0}
发表于 2025-5-29 05:57:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"NYC bridge heights are garbage. A posted NYC bridge height of 12'9\" should be easily accommodated5 a 13'6\" truck.\n\nI think the preferred route in/out, Throggs Neck, posted bridge heights at least that low.","replyToPid":0}
GMT+8, 2026-2-4 13:37 , Processed in 0.075789 second(s), 24 queries .
