查看: 85|回复: 6
Is there a way to create a route using this app?
 楼主| 发表于 2025-5-15 06:07:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"My company creates these elaborate routes to save a buck but I’m not able to create that route in any app. To continue to look at what they’ve instructed and keep my eyes on the road has become a task in itself and is unsafe. \n Thanks for the help.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2025-5-16 09:37:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"As I posted in your other thread, The only way I know to replicate a suggested route is to place random gps points along the intended route to shape it. Like gps says one way but you need to route off another road. Well, on that road, find a rest area, travel stop, etc and add a stop point then move on to the next. Repeat as many times you need. It’s tedious sure but it will get you where you need. Just always remember to double check their suggested route for restrictions and clearances. You pay the fine. Not them. Hope this helped.","replyToPid":0}
1万
发表于 2025-5-15 17:08:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"open your atlas find the starting point and ending point of your trip now look for the straightest line between the two points using the interstates or other big roads... done 👍","replyToPid":0}
发表于 2025-5-15 10:01:29 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Route depends on road conditions and often it's drivers choice. May be they had bad experience in the past. I know a company that was shutdown by FMCSA because they hit 7 bridges in 2 years."}
发表于 2025-5-15 10:05:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"You do get few route options on the GPS but i don't think you can customize your own route.\n\nDo you drive long haul or city?  If you drive longhaul, just paste a sticky paper on the dashboard. They pay you so you have to follow company policies.","replyToPid":0}
发表于 2025-5-15 12:25:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"I just add a city on the route in the direction I need it to route to ensure I get the correct routing then add my fuel or drop location to comply with my company’s routes if the gps doesn’t cooperate. Hope that helps.","replyToPid":0}
发表于 2025-5-19 01:22:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes you can create a route using trucker path way better than copilot","replyToPid":0}
GMT+8, 2026-3-21 18:04 , Processed in 0.065939 second(s), 24 queries .
