查看: 307|回复: 6
HELp! AC STOPPED WORKING
 楼主| 发表于 2025-5-3 04:56:40 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hey guys my truck is a 22 international and the AC has stopped working! I remember when I was given the truck they told me that the little compartment on the side of the truck which holds the compressor if it stops working to unplug or beat or do whatever to the compressor and it should get the AC working! I have done all of those things it’s still not working. Does anybody have any tricks or advice?!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2025-5-3 10:12:39 来自手机 | 显示全部楼层
2673871 发表于 2025-05-03 00:53:40 Is clutch turning? I’m driving is that what you mean?
","text":"no. raise hood while truck is running.  see if ac compressor is turning.  feel ac lines to see if they are cool.","replyToPid":484499}
发表于 2025-5-3 05:39:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"look under the hood. at your ac compressor.  is clutch turning.  I give you some advice.  Just need more information","replyToPid":0}
 楼主| 发表于 2025-5-3 08:53:40 来自手机 | 显示全部楼层
2562995 发表于 2025-05-02 21:39:44 look under the hood. at your ac compressor.  is clutch turning.  I give you some advice.  Just need more information
","text":"Is clutch turning? I’m driving is that what you mean?","replyToPid":484495}
发表于 2025-5-3 09:39:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do you have a fuse tester pen? Open the fuse box and check ac fuse.","replyToPid":0}
 楼主| 发表于 2025-5-3 09:55:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Anyone at the Pilot in Ruther Glen VA? I don’t have a tester pen. Only been driving for two months so still buying things as I need them!","replyToPid":0}
 楼主| 发表于 2025-5-6 08:04:22 来自手机 | 显示全部楼层
2562995 发表于 2025-05-03 02:12:39 no. raise hood while truck is running.  see if ac compressor is turning.  feel ac lines to see if they are cool.
","text":"There was a guy there at the truck stop I was at over the weekend that looked at that specifically! And of course it wasn’t turning so on my way to the Richmond terminal to finally get it fixed!","replyToPid":484504}
GMT+8, 2026-4-16 15:08 , Processed in 0.124321 second(s), 25 queries .
