查看: 21|回复: 2
Small small hole in container tire
 楼主| 发表于 2025-4-22 10:00:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hello everyone, just checking to see if it would be ok for me to drive with a small tiny hole in my rear passenger outer tire on my container(trailer). I was doing a walk around rn and heard it 🤦🏻‍♂️ I’m about 1 hr 45 min away from where I have to drop it off. I’m trying to get a hold of dispatch but I can’t seem to get a hold of someone rn. I’m already shut down for the night and start back up early in AM.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2025-4-23 08:35:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"You should always have a heavy duty tire repair kit along with you , \nSo you can just put a plug in . \nAnd then with a longer hose ether attached direct to ur air supply tanks or from the red trailer hose which you can get adapter hoses for or just make ur own . \nYou then fill air to desired pressure","replyToPid":0}
发表于 2025-4-23 11:12:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"how did it go? was it all flat after you woke up?","replyToPid":0}
GMT+8, 2026-2-4 22:46 , Processed in 0.420476 second(s), 24 queries .
