查看: 45|回复: 23
Summer is Coming!!!
 楼主| 发表于 2025-3-26 06:23:36 来自手机 | 显示全部楼层 |阅读模式
{"text":"Anyone got any hacks on keeping cabs cool during the summer???? It's almost 90 degrees in Louisiana at 5 pm and it's not even APRIL yet!!!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2025-3-26 09:51:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"cold beer in the fridge","replyToPid":0}
回复 支持 4 反对 1
发表于 2025-3-26 23:51:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Make sure to get your A/C serviced.\n\nOn 34hr breaks or 10hr breaks if you stop while the sun is still up, close the windshield curtains. That cuts down on hope much sun gets into the cab.","replyToPid":0}
发表于 2025-3-28 04:43:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"one thing I do is get the cheap windshield things cut to fit side windows and fit front windshield( need reflective.... pull curtains around windshield... then also pull curtains at sleeper","replyToPid":0}
发表于 2025-3-27 10:14:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"I bought this small AC/humidifier from Amazon. I load icy cold water in it and it blows cold air enough to keep the sleeper cool.\n\nI don't like idling also got no APU. Also as other rookies said park against sun rays and close the curtains...it all helps.","replyToPid":0}
 楼主| 发表于 2025-3-27 06:20:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"hahahaha 😂","replyToPid":483873}
发表于 2025-3-27 04:03:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"If possible, try to park with your back to the setting sun. Close your curtains, and run your AC for a bit to cool off  the interior. I also have a fan to keep the air circulating.","replyToPid":0}
发表于 2025-3-26 19:14:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Drunk","replyToPid":483873}
发表于 2025-3-30 23:18:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"No pjs","replyToPid":0}
发表于 2025-3-27 17:19:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"I was In Lafayette yesterday and yes it was summer already down there","replyToPid":0}
 楼主| 发表于 2025-3-27 06:22:26 来自手机 | 显示全部楼层
665190 发表于 2025-03-26 15:51:57 Make sure to get your A/C serviced.\n\nOn 34hr breaks or 10hr breaks if you stop while the sun is still up, close the windshield curtains. That cuts down on hope much sun gets into the cab.
","text":"thanks 😊","replyToPid":483886}
发表于 2025-3-26 06:54:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"buy some good window shades. I also use turbo fan. with my ac to keep truck comfortable","replyToPid":0}
发表于 2025-3-26 23:54:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"aww did you get misgendered again?","replyToPid":483881}
 楼主| 发表于 2025-3-27 06:21:05 来自手机 | 显示全部楼层
2562995 发表于 2025-03-25 22:54:46 buy some good window shades. I also use turbo fan. with my ac to keep truck comfortable
","text":"thanks 😊","replyToPid":483869}
 楼主| 发表于 2025-3-27 06:21:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"LoL 😂","replyToPid":483881}
GMT+8, 2026-2-5 07:00 , Processed in 0.075099 second(s), 24 queries .
