查看: 70|回复: 5
Petro in Mableton, Ga any good?
 楼主| 发表于 2025-3-25 23:18:52 来自手机 | 显示全部楼层 |阅读模式
{"text":"Getting unloaded right down the road from the Petro. It is any good?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2025-3-26 06:57:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't waste my time with TA. I have reserved parking in past. Before I arrive . Then I get there and I'm told they don't have my spot because someone parked illegally.   They can't make them move. The franchise is overpriced on everything","replyToPid":0}
发表于 2025-3-26 09:51:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"HAHAHAHA","replyToPid":0}
发表于 2025-3-26 05:18:16 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I generally avoid it. Had several bad experiences. Parking fills early and it's a hybrid ticket/reservation setup. Very often your reserved spot will be occupied by someone with a ticket but no reservation.\n\nUnless things have changed they don't care and won't clear your space."}
发表于 2025-3-26 07:31:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"everything that close to ATL is highly suspect... I hope it worked out for you. if you got there before noon, it might not have been too bad.","replyToPid":0}
发表于 2025-3-28 06:47:59 来自手机 | 显示全部楼层
2562995 发表于 2025-03-25 22:57:38 I don't waste my time with TA. I have reserved parking in past. Before I arrive . Then I get there and I'm told they don't have my spot because someone parked illegally.   They can't make them move. The franchise is overpriced on everything
","text":"They absolutely CAN make them move. They can escalate all the way up to having the police trespass them off the property and towing their truck.\n\nThey either choose to not do anything or have been ordered to not do anything.","replyToPid":483870}
GMT+8, 2026-4-18 04:07 , Processed in 0.087477 second(s), 24 queries .
