查看: 82|回复: 9
14 hr clock
 楼主| 发表于 2025-3-15 08:40:44 来自手机 | 显示全部楼层 |阅读模式
{"text":"This is my first week ever driving OTR can somebody please explain why or how I have more time on my 11 hour clock than I do on my 14 hour clock","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2025-3-16 08:38:26 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"14 hours is your whole shift. Within the shift you have 11 hours of driving.\n\nIf you stay in place, stop to get fuel, take a 30 min break, eat, and so on - your shift time is still running.\n\nTherefore you're left with more driving time."}
回复 支持 6 反对 0
发表于 2025-3-15 09:39:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Probably if you were sitting on duty loading and unloading or fueling you 14 caught up with your 11.","replyToPid":0}
发表于 2025-3-21 19:53:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you take a 2 hour break it might reset the 14 hour clock.","replyToPid":0}
发表于 2025-3-18 04:59:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"The drive clock stops when you stop driving. The 14hr clock pretty much never stops. So it's very common to have more drive time than you're 14hr clock time if you had even a moderate wait loading or unloading.\n\nMost ELDs will display your drive time limited to your 14hr daily or even your 60/70hr weekly clock.","replyToPid":0}
发表于 2025-4-2 20:34:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"That shouldn’t happen because once your 14 hr clock drops below your drive clock the drive time and 14 should be equal because no matter how much drive time is left you can’t drive past your time left on 14.","replyToPid":0}
发表于 2025-3-18 11:31:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"I call this burning my 14 😂","replyToPid":0}
发表于 2025-3-15 19:42:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yea what that gentleman said so if 11 is your drive hours if your driver status is not in driving than it stops but everything else keeps going usually means you’ve been either waiting a lot at shippers/consignee","replyToPid":0}
发表于 2025-7-3 21:13:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"once you start, that 14 hr don't stop. if your at a customer,  eating, rest stop, that 14 keeps running. the only time your eleven runs is while your driving.","replyToPid":0}
发表于 2025-7-17 08:41:42 来自手机 | 显示全部楼层
2676982 发表于 2025-07-03 13:13:04 once you start, that 14 hr don't stop. if your at a customer,  eating, rest stop, that 14 keeps running. the only time your eleven runs is while your driving.
","text":"or if your 14 runs less than your 11 it will start taking available drive time.","replyToPid":485657}
GMT+8, 2026-4-18 20:17 , Processed in 0.149507 second(s), 24 queries .
