查看: 10|回复: 3
going through NYC i95
 楼主| 发表于 2025-3-10 00:01:23 来自手机 | 显示全部楼层 |阅读模式
{"text":"hi guys, so I'm planning on taking the I95 through NYC coming from Rhode Island Providence going to Montgomeryville in PA. trucker path suggested to take I95. I could use I84 but I like to take a glimpse of the city skyline. any of you guys have experience going that route? I'm aware of heavy traffic I'm willing to put up with it, since I don't know if I'll be coming back this way so it might be my only chance to see NYC. \nany advice or suggestions? safe to go down that way?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2025-3-10 10:19:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bro I take that route everyday and believe me you not gonna see nothing about NYC u gonna cross the bronx and then u get the GW bridge and that's it, good luck tho...","replyToPid":0}
回复 支持 7 反对 0
发表于 2025-3-10 22:19:39 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"TP deleted my post because I called NYC bridge height laws...less than intelligent.🙄\n\nBe aware that NYC, and ONLY NYC, posts bridge heights about 3-5ft less than the true height (1-1.5m in Canadian 😁).  You can go thru NYC on I-95 but you WILL see posted bridge heights less than the height of your truck. Also be aware the bridge heights will go back to realistic with no warning when you leave."}
发表于 2025-3-14 08:17:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"😂😂😂","replyToPid":0}
GMT+8, 2026-2-5 03:44 , Processed in 0.120334 second(s), 24 queries .
