查看: 33|回复: 10
grabbing gears
 楼主| 发表于 2025-3-3 09:25:39 来自手机 | 显示全部楼层 |阅读模式
{"text":"any advice for someone transitioning from automatic to an 18 speed hauling logs?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2025-3-4 07:54:15 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Learn to be patient don't need to rush or force it. Enough practice you will be fine. Learn to feel the r.p.m. and speed of the truck watch the tach then after a little while it will flow (shift) freely. Being an operator is a \"feel\". The auto although my left knee appreciates it takes the operator out of the truck!\nAlso logs and mud and being in the bush is a different life compared to the other trailer truckin. Feel free to axe any questions. We will help!"}
回复 支持 2 反对 4
发表于 2025-3-11 20:59:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"don't really need to split the bottom half, I only had to do it once. I was comin off a side road turnin up a steep little hill on the hiway weighin 90k. Just regular drivin though no need for it. I would split the last on the low side, it just made a smaller jump to the high side.","replyToPid":0}
发表于 2025-3-6 08:16:30 来自手机 | 显示全部楼层
2604824 发表于 2025-03-04 11:43:23 🤔  I wonder....... you work at Walmart  and your famous for saying  WELCOME TO WALMART.   when did you get driving experience
","text":"That job was discontinued years ago. I'm in stocking and the dock.","replyToPid":483662}
发表于 2025-3-4 19:43:23 来自手机 | 显示全部楼层
2571469 发表于 2025-03-03 23:54:15 Learn to be patient don't need to rush or force it. Enough practice you will be fine. Learn to feel the r.p.m. and speed of the truck watch the tach then after a little while it will flow (shift) freely. Being an operator is a \"feel\". The auto although my left knee appreciates it takes the operator out of the truck!\nAlso logs and mud and being in the bush is a different life compared to the other trailer truckin. Feel free to axe any questions. We will help!
","text":"🤔  I wonder....... you work at Walmart  and your famous for saying  WELCOME TO WALMART.   when did you get driving experience","replyToPid":483650}
 楼主| 发表于 2025-3-3 22:39:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's literally bubble gum 👍","replyToPid":0}
1万
发表于 2025-3-3 17:51:41 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"👍 🇺🇸 🙂"}
发表于 2025-3-3 23:12:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Drive 18spd everyday.  Best transmission ever made","replyToPid":0}
1万
发表于 2025-3-3 23:24:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"sorry...\n I made a mistake...\n👍 🇺🇸 🙂","replyToPid":0}
发表于 2025-3-13 11:58:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"yeah don't worry about the low gears so much unless fully loaded headed up a steep incline it's finding those happy mediums trying to climb at about 35 40mph that's when spitting them sure comes in handy and of course the money gear #18saves on gas and hauls u know","replyToPid":0}
GMT+8, 2026-2-5 02:10 , Processed in 0.089937 second(s), 24 queries .
