查看: 141|回复: 8
🤬ing Commifornia!
 楼主| 发表于 2025-1-16 21:29:13 来自手机 | 显示全部楼层 |阅读模式
{"text":"Commifornia is trying to extract more revenue from truck drivers.\n1. They are claiming that pre/post trip inspections must last 15minutes or they'll ticket you. The 15minutes is from paper logs that had minimum 15minute time blocks\n2. They are also claiming that the amount of time the DVIR is open is the amount of time spent on inspection. Ignoring the fact that electronic DVIRs aren't a checklist like a paper one and the fact that the elog has an \"inspection\" status to indicate how long to spent on inspection.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2025-1-17 03:33:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"i quit running California because of rules they have. They are most corrupt state in America.  i got no sympathy for what's going on now. Hopefully good comes from it","replyToPid":0}
发表于 2025-1-17 02:19:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"They are wrong. You are correct. The 15 is from paper","replyToPid":0}
发表于 2025-1-18 05:25:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"15 is from paper but it's a round up/down.  so technically the inspection lasts between 7.5-22.5 minutes on a paper log. so 10 min is between the range of a paper log. also the Supreme Court ruled on the chevron case that they have to follow the law as it's written and anything vague has to be sent back to the legislature for clarification and cannot be interpreted by anyone but the legislators as a law.","replyToPid":0}
发表于 2025-1-24 19:50:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Weird… I run in California all the time and when I got inspected my logs had 6 min on my pre/post trips and my DVIR is open for like 1min just to note anything from the inspection & they had zero issues. \n\nMaybe California doesn’t like you as much as you don’t like it.","replyToPid":0}
发表于 2025-1-25 02:41:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Who told you that? I have been pulled in for class 1 inspections around a half dozen times at the Mountain Pass weigh station. They never once questioned my pre trip inspection times.","replyToPid":0}
发表于 2026-2-7 23:57:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sue the state.","replyToPid":0}
发表于 2025-1-20 00:52:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"LMAO! Tell them your lawyer will be glad to deal with that. There is no time requirement under Fed rules, it just has to be noted done.","replyToPid":0}
 楼主| 发表于 2025-1-19 01:28:05 来自手机 | 显示全部楼层
517558 发表于 2025-01-17 21:25:34 15 is from paper but it's a round up/down.  so technically the inspection lasts between 7.5-22.5 minutes on a paper log. so 10 min is between the range of a paper log. also the Supreme Court ruled on the chevron case that they have to follow the law as it's written and anything vague has to be sent back to the legislature for clarification and cannot be interpreted by anyone but the legislators as a law.
","text":"Yes but you'd need to fight Commifornia to get them to admit that. The company I worked for didn't deem that worthwhile.","replyToPid":483237}
GMT+8, 2026-3-21 14:17 , Processed in 0.058424 second(s), 24 queries .
