查看: 129|回复: 4
DOT question
 楼主| 发表于 2025-1-10 22:35:26 来自手机 | 显示全部楼层 |阅读模式
{"text":"Lost my RH lower fender when steer blew out. Hood intact and metal frame for lower is fine which includes the mud flap. Will I get popped if I keep running or is it ok because mud flap still there. Pete 386","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2025-1-11 09:16:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"It depends on the officer. It sounds like you are good to go.","replyToPid":0}
发表于 2025-1-12 21:54:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just another reason to look deeper and find more.","replyToPid":0}
发表于 2025-1-10 22:37:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes you will. because its defective equipment","replyToPid":0}
1万
发表于 2025-1-16 17:59:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"sounds like you need some duct tape and zip ties...\n🙂 🇺🇸 👍","replyToPid":0}
GMT+8, 2026-4-15 10:05 , Processed in 0.087229 second(s), 24 queries .
