查看: 49|回复: 3
Volvo governor
 楼主| 发表于 2025-1-1 10:42:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"anybody know which software I need to change this factory governor setting on a 2016 Volvo d13 I can't get barely to 68 I'd like to at least do the speed limit","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2025-1-1 21:20:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"All you need is scanner with volvo software.  i got scanner with detroit and cummins  I use for my trucks","replyToPid":0}
回复 支持 4 反对 1
发表于 2025-1-4 01:08:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Like high spade says.","replyToPid":0}
 楼主| 发表于 2025-1-8 19:12:47 来自手机 | 显示全部楼层
1060944 发表于 2025-01-01 13:20:13 All you need is scanner with volvo software.  i got scanner with detroit and cummins  I use for my trucks
","text":"ok ... that's what i figured... what should I pay a guy if I don't want to shell over cash for the setup?","replyToPid":483087}
GMT+8, 2026-2-4 10:48 , Processed in 0.081684 second(s), 24 queries .
