查看: 75|回复: 6
Sleeper berth split help
 楼主| 发表于 2024-12-14 07:44:34 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have a firm appointment scheduled for 10 pm and I’m currently waiting. Dont know if i should apply a Sb split or go off duty to stop my 14 hour clock? My 14 hour clock is still dropping and I’m left with four hours 30 minutes left.  New solo over guy here.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-12-14 09:51:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Your 14 hour will tick regardless of your status. Best you go on sleeper to start your 10 hour reset.\n\nAt least you won’t have to sit there for another 10 hours after you’re empty. As long as you drive under 5 mph… it won’t trigger your driving log.","replyToPid":0}
发表于 2024-12-15 22:09:03 来自手机 | 显示全部楼层
622924 发表于 2024-12-14 01:51:13 Your 14 hour will tick regardless of your status. Best you go on sleeper to start your 10 hour reset.\n\nAt least you won’t have to sit there for another 10 hours after you’re empty. As long as you drive under 5 mph… it won’t trigger your driving log.
","text":"Be VERY careful about the 5mph too. It's very easy to accidently go on the driving clock. It used to be 10mph which was fairly reasonable. 5mph is just asinine.","replyToPid":482878}
发表于 2024-12-16 21:13:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"For future reference,  if Split is enabled on your log, off-duty for 2 hours or more will put the clock back to when u first went off-duty. Use sleeper- berth if you are stopping for 7 hours or more. If u did not use sleeper-berth for 7 hours in the first segment,  be very sure to have at least 7 hours on sleeper-berth when you do ur 10 hour break. if u don't, you will be in violation.","replyToPid":0}
发表于 2024-12-17 00:10:39 来自手机 | 显示全部楼层
665190 发表于 2024-12-15 14:09:03 Be VERY careful about the 5mph too. It's very easy to accidently go on the driving clock. It used to be 10mph which was fairly reasonable. 5mph is just asinine.
","text":"mine kicks in at 4mph","replyToPid":482905}
发表于 2024-12-16 23:58:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"always go on sleeper. the long split has to be in the sleeper mode. the short split doesn't matter but needs to be at least 2 hours for it to count. after you have at least 1 two hour or better they all will be factored in.","replyToPid":0}
发表于 2024-12-23 16:38:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just shut your computer off","replyToPid":0}
GMT+8, 2026-3-21 06:10 , Processed in 0.103737 second(s), 24 queries .
