查看: 59|回复: 2
repair tips
 楼主| 发表于 2024-12-4 08:12:06 来自手机 | 显示全部楼层 |阅读模式
{"text":"got oil leaking from my front driver steer wheel how hard is it to replace hub seals? I've been a passenger vehicle mechanic for years so have some know how just have it worked on large trucks... also how long can I last if I continue to fill the hub oil up when necessary before this week becomes a major issue","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-12-4 09:35:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's easy repair.  Just filling it with oil. isn't good idea. if your luck is like mine. Dot see it. repair going to cost you whole lot more","replyToPid":0}
 楼主| 发表于 2024-12-4 14:11:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"thank you .. gonna handle it today after I drop","replyToPid":0}
GMT+8, 2026-4-17 04:28 , Processed in 0.089486 second(s), 23 queries .
