查看: 102|回复: 3
Tip or Advice for someone looking to make the move to Owner Operator?
 楼主| 发表于 2024-10-19 01:12:37 来自手机 | 显示全部楼层 |阅读模式
{"text":"If any owner operators out there want to help this fellow trucker do some homework on starting up his LLC and have any advice, things to consider or just any solid tips or tricks for getting started I would sure appreciate it. \nI've done a fair amount of homework so far and talk to a few owner operators but it never hurts to continue doing so! \n\nThank you in advance and God Bless!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-10-21 10:34:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have plenty money set aside. If your not in them you understand them.","replyToPid":0}
发表于 2025-2-26 19:14:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"have you looked into carrier forge?  They help you get every thing you need and take all of the paper work and roadwork out for you cause it is some time consuming for you too do it. they do all of that for you from tax id. to mc and dot numbers etc. of course it's a little money but not as much as you would think. look them up and Happy trails.","replyToPid":0}
发表于 2025-3-1 10:16:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"DONT!","replyToPid":0}
GMT+8, 2026-4-15 10:05 , Processed in 2.818274 second(s), 24 queries .
