查看: 20|回复: 4
New opportunities
 楼主| 发表于 2024-10-9 03:55:55 来自手机 | 显示全部楼层 |阅读模式
{"text":"So I’m currently with Werner enterprises just under three years experience. I live in the central Texas area with a Twic card and am currently getting my endorsements. I was recently approached by a recruiter for an opportunity with swifts Walmart account. I just have to know is it worth it?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
1万
发表于 2024-10-9 07:59:52 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"if you want to drive for Walmart, try and go to Walmart direct, don't work for someone contracted to Walmart... \n🙂 🇺🇸 👍"}
回复 支持 8 反对 0
发表于 2024-10-9 10:58:57 来自手机 | 显示全部楼层
2498086 发表于 2024-10-09 02:57:45 Walmart requires 30 months of verifiable OTR to qualify to apply as a driver with them.
","text":"Here’s a link for a Walmart Trainer who explains EXACTLY what is required…\n\nhttps://youtu.be/uqNdc01vJYA?si=7zHF64mgLVz7LMXC","replyToPid":482038}
发表于 2024-10-9 10:57:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Walmart requires 30 months of verifiable OTR to qualify to apply as a driver with them.","replyToPid":0}
发表于 2024-10-10 03:26:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Going from Werner to Swift is a lateral move. If you meet Walmarts qualifications, go and apply directly with Walmart. It will help you if you use a current Walmart driver as a referral. If you don't know one, next time you run into one, ask him for his driver number.","replyToPid":0}
GMT+8, 2026-2-5 11:25 , Processed in 0.076804 second(s), 24 queries .
