查看: 171|回复: 3
14 hour clock
 楼主| 发表于 2019-6-11 00:37:33 来自手机 | 显示全部楼层 |阅读模式
{"text":"How do you stop the clock if you start your pre trip and your load gets cancelled? ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-6-28 18:13:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"An if you can’t do it contact your safety person they should be able to ","replyToPid":0}
发表于 2019-6-11 03:02:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can edit it to off-duty then give the reason why your editing it in the notes. depending on how long it takes you to get another load you should be alright.","replyToPid":0}
发表于 2019-6-28 21:21:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you haven't driven any, you can edit ur logs most times and change on duty to off duty... unless you drive. cant edit that","replyToPid":0}
GMT+8, 2026-4-18 07:01 , Processed in 0.084771 second(s), 24 queries .
