查看: 146|回复: 10
Robbed of Jobs
 楼主| 发表于 2024-10-2 08:24:48 来自手机 | 显示全部楼层 |阅读模式
{"text":"I recently lost my job due to a so called following distance safety violation... But it's restricting me fom being able to get another job keep applying but continue to be turned down by companies even though have no accident record..Please help if you know where I can get a driving job.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-10-7 11:08:12 来自手机 | 显示全部楼层
665190 发表于 2024-10-02 04:47:29 A following distance violation is when you are tailgating. If your truck has collision avoidance or cruise control it measures how close your are to the vehicle in front of you. Pretty easy to have the truck report if you tailgate to the company.
","text":"That sounds ridiculous. I wouldn't drive a truck like that.","replyToPid":481971}
回复 支持 0 反对 7
发表于 2024-10-2 11:54:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"wth is following distance violation? And how do they know to fire you? Ask high spade she (tranny) loves desperate drivers.","replyToPid":0}
回复 支持 1 反对 4
发表于 2024-10-3 08:16:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Following too closely is not that serious violation, and it won't affect their score. I believe there is more like your availability or attendance and they just don't want you in the company. There are carriers out there will hire you even if you have at fault accident. Keep trying I'm sure you will find some good company.","replyToPid":0}
发表于 2024-10-3 06:43:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Mega carrier has more strict policy than small companies. I would browse indeed","replyToPid":0}
发表于 2024-10-2 12:47:29 来自手机 | 显示全部楼层
2488860 发表于 2024-10-02 03:54:56 wth is following distance violation? And how do they know to fire you? Ask high spade she (tranny) loves desperate drivers.
","text":"A following distance violation is when you are tailgating. If your truck has collision avoidance or cruise control it measures how close your are to the vehicle in front of you. Pretty easy to have the truck report if you tailgate to the company.","replyToPid":481966}
发表于 2024-10-7 12:12:15 来自手机 | 显示全部楼层
2488860 发表于 2024-10-07 03:08:12 That sounds ridiculous. I wouldn't drive a truck like that.
","text":"You can't drive a truck without tailgating?","replyToPid":482009}
发表于 2024-10-3 04:27:17 来自手机 | 显示全部楼层
","text":"Especially with theses amazon trucks camera watches u for everything’s even yawning u will be pinged for..","replyToPid":481966}
发表于 2024-10-3 06:17:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Where are you located?","replyToPid":0}
发表于 2024-10-5 20:01:43 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"don't apply at any megas for the most part, try smaller companies. check your dac record see if they put anything on there."}
发表于 2024-10-6 19:59:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Must’ve been Swift.","replyToPid":0}
GMT+8, 2026-4-17 08:57 , Processed in 0.116513 second(s), 24 queries .
