查看: 140|回复: 12
Newbie 🚛
 楼主| 发表于 2024-9-19 03:11:09 来自手机 | 显示全部楼层 |阅读模式
{"text":"New to the trucker life , on my second load. Dallas to Ohio. Any advice or tips anyone can give would be awesome 🤘🏻","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-9-19 12:45:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"don't wear flipflops","replyToPid":0}
回复 支持 10 反对 0
发表于 2024-9-22 09:54:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Taking your time when backing don't let NO ONE RUSH YOU!! This way you DONT hit anyone. If you need someone to spot you for backing, if someone up in there chair just ask drivers. When I was new so many ppl was willing to help when I asked. Remember when in doubt pop yo brakes and get out and look.  Pls. Good luck 🤙🏾","replyToPid":0}
回复 支持 5 反对 1
发表于 2024-9-19 10:23:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Trucker path will be your best friend for parking!!!\n\nAlways cross reference google and gps 👍","replyToPid":0}
回复 支持 6 反对 0
发表于 2024-9-19 07:53:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"when you make a mistake don't over think it and make a bigger mistake.","replyToPid":0}
回复 支持 4 反对 1
 楼主| 发表于 2024-9-19 04:32:55 来自手机 | 显示全部楼层
1060944 发表于 2024-09-18 20:15:02 Always watch 4 wheelers.  Because they don't care
","text":"Yea had a couple of scares already from 4 wheelers cutting me off. Just going to always keep my distance","replyToPid":481842}
发表于 2024-9-19 04:15:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Always watch 4 wheelers.  Because they don't care","replyToPid":0}
发表于 2024-9-22 05:49:13 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Keep it cool even if people around you are a-holes.\n\nWhen you park for the night always pull forward couple of inches. That puts tension on the locking jaws and keeps people from pulling your kingpin during the night.\n\nALWAYS check you kingpin release arm EVERY time you return to your truck. Every. Time.\n\nTest you trailer spring brake and service brake every morning. There is a way people can disable either one. Pull the red knob and idle forward to make sure the spring brake works. Then push in the red knob, pull the trailer brake lever and idle forward again to make sure the trailer service brake is working.\n\nI'm not about to state, in a public forum, how someone can mess with the trailer brakes."}
1万
发表于 2024-9-22 19:40:08 来自手机 | 显示全部楼层
{"replyToPid":481873,"replyTo":"
665190 发表于 2024-09-21 21:49:13 Keep it cool even if people around you are a-holes.\n\nWhen you park for the night always pull forward couple of inches. That puts tension on the locking jaws and keeps people from pulling your kingpin during the night.\n\nALWAYS check you kingpin release arm EVERY time you return to your truck. Every. Time.\n\nTest you trailer spring brake and service brake every morning. There is a way people can disable either one. Pull the red knob and idle forward to make sure the spring brake works. Then push in the red knob, pull the Jake brake lever and idle forward again to make sure the trailer service brake is working.\n\nI'm not about to state, in a public forum, how someone can mess with the trailer brakes.
","text":"I never heard it called a \"Jake Brake Lever\" ??? I thought it was called a \"Trolley Brake\" or \"hand brake valve\" for operating the trailer brakes only ??? the \"Jake Brake\" has to do with engine braking...\nBut what do I know ???\n 🙂 🇺🇸 👍"}
发表于 2024-9-22 02:54:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"you might get an inspection in Ohio, those dot guys are bored and desperate.","replyToPid":0}
发表于 2024-9-22 04:32:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Never get too comfortable once you do mistakes start happening and make sure you get yourself a cb very helpful in traffic jams","replyToPid":0}
GMT+8, 2026-4-17 02:18 , Processed in 0.109377 second(s), 24 queries .
