查看: 55|回复: 13
Kenworth software
 楼主| 发表于 2024-9-10 20:49:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hello. Im looking to disable my collision mitigation system. It keeps slamming on the brakes when I pass under bridges and would cost a lot of money to replace. Replacement would be ok in normal circumstances but I find the system completely useless. Unplugging it triggers the ABS light and disables cruise control. Anyone in the Indianapolis area willing to or know how to do this? Obviously I’d compensate you. There’s also delete work after that if you’d be interested. Thanks.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-9-12 21:12:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"F.Y.I. in the event of an accident, the insurance company finds out it was tampered with, they will not pay out.","replyToPid":0}
回复 支持 3 反对 4
发表于 2024-9-11 00:24:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have you tried having it recalibrated?","replyToPid":0}
发表于 2024-9-12 20:04:49 来自手机
{"replyTo":"","text":"My International does this same crap!","replyToPid":0}
支持 3 反对 1
发表于 2024-9-29 22:10:25 来自手机 | 显示全部楼层
2488860 发表于 2024-09-12 13:12:42 F.Y.I. in the event of an accident, the insurance company finds out it was tampered with, they will not pay out.
","text":"This comes from a swift driver","replyToPid":481794}
发表于 2024-9-21 20:16:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"there's a 10 Amp fuse in the box on the firewall. It will not affect your ABS if you take the fuse out. It does disable the front mitigation system. My Peterbilt did the same thing yours is doing.","replyToPid":0}
发表于 2024-9-17 11:58:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hate it! Worst thing ever!","replyToPid":0}
发表于 2024-9-17 12:01:32 来自手机 | 显示全部楼层
{"replyToPid":481790,"replyTo":"
1399473 发表于 2024-09-12 12:04:49 This comment has been deleted
","text":"same here"}
发表于 2024-9-11 04:30:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Well, this is a pretty easy one to fix you can disconnect it… your ABS light should go as soon as you start driving after you hit 5 mph if it doesn’t, then it’s not gonna work… how do you get your cruise control back pretty easy… you’re gonna have to hit your cruise control on and off and then you could still use your cruise control every time there’s guides for it on YouTube","replyToPid":0}
 楼主| 发表于 2024-9-11 16:22:15 来自手机 | 显示全部楼层
925557 发表于 2024-09-10 16:24:53 Have you tried having it recalibrated?
","text":"Yea, twice now.","replyToPid":481781}
 楼主| 发表于 2024-9-11 16:30:18 来自手机 | 显示全部楼层
824706 发表于 2024-09-10 20:30:42 Well, this is a pretty easy one to fix you can disconnect it… your ABS light should go as soon as you start driving after you hit 5 mph if it doesn’t, then it’s not gonna work… how do you get your cruise control back pretty easy… you’re gonna have to hit your cruise control on and off and then you could still use your cruise control every time there’s guides for it on YouTube
","text":"I disconnected the collision mitigation sensor but the ABS light wont go out. The cruise control is adaptive so it uses a sensor in the collision mitigation system.","replyToPid":481785}
发表于 2024-9-12 22:18:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Unplug it for 30 minutes then plug it back in. Mine did that, and it rebooted itself after I did that.","replyToPid":0}
发表于 2024-9-12 22:20:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Someone stole my radar thing on the front of my truck. Hitting the cruise control several times until the light comes on, then I can set the cruise without the radar on the truck. 2016 Freightliner cascadia","replyToPid":0}
GMT+8, 2026-2-5 06:14 , Processed in 0.113707 second(s), 24 queries .
