查看: 137|回复: 5
frame straighten/alignment
 楼主| 发表于 2024-9-9 01:24:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can anyone tell me where the dude, \"bendinwithbeckam\" works in Houston? I've seen his videos on the YouTube and would like for him to look at the truck.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-9-10 10:17:13 来自手机 | 显示全部楼层
665190 发表于 2024-09-09 12:56:42 I thought a bent frame was a \"junk the truck\" sort of problem. Once you bend metal past the point where it bounces back its weakened.
","text":"not anymore any repair is possible.","replyToPid":481766}
回复 支持 1 反对 3
发表于 2024-9-9 01:45:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Did you contact him thru YouTube?","replyToPid":0}
发表于 2024-9-9 20:56:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"I thought a bent frame was a \"junk the truck\" sort of problem. Once you bend metal past the point where it bounces back its weakened.","replyToPid":0}
 楼主| 发表于 2024-9-9 23:29:03 来自手机 | 显示全部楼层
1060944 发表于 2024-09-08 17:45:50 Did you contact him thru YouTube?
","text":"I've tried. Thank you.","replyToPid":481757}
 楼主| 发表于 2024-9-9 23:30:11 来自手机 | 显示全部楼层
","text":"He does more than bent frame work. Alignments, frame stretching, etc.","replyToPid":481766}
GMT+8, 2026-4-15 10:05 , Processed in 1.999470 second(s), 25 queries .
