查看: 64|回复: 3
Weigh Stations
 楼主| 发表于 2024-8-27 23:45:06 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hey folks,\n\nAsking about weigh stations over on the ID, WA border on I-90. The company I work for usually ignores them as we've had bad experiences in the past with them (the DOT agents give us a hard time about coming over the scales in the first place and one has even made clear that we were wasting his time). That being said, we used to just drive trucks with a GVW of 18000+ max. Recently, we acquired two used M2 Freightliners for our work. We were still asked to skip the scales and have thus far had no problems still. The freightliners are 26,000 GVW. How serious of an issue is it for us to be skipping the scales in those instances with those vehicles? Our loads normally consist of hard good donations (tools, appliances, furniture, electronics, clothes, books, etc.) or food donations. What are your guys' thoughts?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-8-28 00:48:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"I give you valuable advice.  it's your license!    The fine will be given to you. If it's not paid. Your responsible.  Remember that","replyToPid":0}
发表于 2024-8-29 06:36:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"With those M2 trucks, yes, you will need to go across the scale. Doesn't matter what your cargo is. If your total weight is over a certain amount, don't pass the scale.\n\nAs the driver, you assume all responsibilities being on the road, and any ticket will be given directly to you; even if your company tells you to skip the scale. High Spade is right. It's YOUR license, so make choices that protect you. Even if that means telling your company No.","replyToPid":0}
发表于 2024-8-29 08:38:09 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"There is not a scale in this country that you can not take a scenic route around. tic-tac-toe sign outlaw truckin"}
GMT+8, 2026-4-17 08:56 , Processed in 0.094024 second(s), 24 queries .
