查看: 67|回复: 3
Best Dash Cam of 2024?
 楼主| 发表于 2024-8-25 08:00:57 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm shopping around for a Dash Cam to put in the company rig. Are there any preferred brands out there? Any Must Have abilities the Dash cam needs? Such as 1080p resolution, etc.? It seems having a wide angle lense is a must-have on any cam.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-8-27 02:11:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use a Garmin 47 and absolutely love it. I’ve had it for years and not once have I had to replace the SD card. It’s 1080P with wide angle lens. It’s also WiFi compatible showing you to connect to Internet in your truck if you have a portable hotspot. Which allows you to view the live feed from anywhere as long as you have service. It also notifies you if someone hits your vehicle while you’re away and saves the video. \nWon’t go with anything else.","replyToPid":0}
发表于 2024-8-25 21:31:20 来自手机 | 显示全部楼层
{"replyToPid":481615,"replyTo":"
207357 发表于 2024-08-25 04:28:43 This comment has been deleted
","text":"I use Rexing as well. no problems either"}
发表于 2024-8-25 21:05:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Garmin 67W","replyToPid":0}
发表于 2024-8-25 12:28:43 来自手机
{"replyTo":"","text":"A driver friend of mine has a Rexing he loves it, and uses it for his trucking YouTube channel. I use my Garmin that is built into the GPS, but I'd rather use a separate cam, I plan on buying a Rexing, it's USA based to. You can see more on it here https://www.rexingusa.com.  He's never had any problems with it.","replyToPid":0}
支持 1 反对 0
GMT+8, 2026-4-15 11:46 , Processed in 0.104169 second(s), 25 queries .
