查看: 17|回复: 8
Lease to Own
 楼主| 发表于 2024-8-1 08:58:29 来自手机 | 显示全部楼层 |阅读模式
{"text":"Are there any good companies out there to lease to own from, or are they all just a scam???","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-8-2 17:15:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"My recommendation would be to lease a truck from an independent leasing agent rather than directly from the trucking company. This way, if the company goes out of business or you decide to leave the company, you won't lose all the money you've invested in the truck, and you won't be forced to return it. By leasing from an independent agent, you have the flexibility to take your truck to any company you choose, offering greater freedom and security.","replyToPid":0}
发表于 2024-8-6 09:03:56 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I do NOT recommend leasing. especially at this current time. they are probably 98 percent a money pit. not necessarily a scam. you are basically doing all the work and making all the payments for the company while they reap rewards and compensate you only a bit more than a company driver. at the end if the lease you will have to likely make a huge Balloon payment or refinance said payment. that's when they get u to lease yet a newer model.\n\nPS ..they almost always talk a big dream to newer drivers with under a year experience.  I say run"}
1万
发表于 2024-8-1 20:22:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"I never heard anything good about a lease to own... \nhow much experience do you have ??? my advice would be find a good company driver job and if you want to own a truck, save money while you get experience and figure out if you want the added expenses of owning a truck...\n 🙂 🇺🇸 👍","replyToPid":0}
发表于 2024-8-4 09:17:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"No! Absolutely the worst decision ever!. \nbuy your own!","replyToPid":0}
发表于 2024-8-29 19:46:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t lease !!! Bad idea!!! Trust me I found out the hard way","replyToPid":0}
发表于 2024-8-7 03:48:40 来自手机 | 显示全部楼层
2071292 发表于 2024-08-06 01:03:56 I do NOT recommend leasing. especially at this current time. they are probably 98 percent a money pit. not necessarily a scam. you are basically doing all the work and making all the payments for the company while they reap rewards and compensate you only a bit more than a company driver. at the end if the lease you will have to likely make a huge Balloon payment or refinance said payment. that's when they get u to lease yet a newer model.\n\nPS ..they almost always talk a big dream to newer drivers with under a year experience.  I say run
","text":"Sound advice 👍","replyToPid":481440}
发表于 2024-8-3 20:19:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"basically the same depending on the situation and the company everything is different because dispatch matters and that's just it","replyToPid":0}
发表于 2024-8-9 11:12:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can come check out my company","replyToPid":0}
GMT+8, 2026-2-5 08:26 , Processed in 0.117057 second(s), 24 queries .
