查看: 117|回复: 13
Drive Tire is smoking and oil all around
 楼主| 发表于 2024-7-17 00:19:56 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hello Everyone, I hope You all are having a BigSmile today.\nCan someone please explain what may cause a “Tire Smoking and showing oil around it” please ? \nAnd how dangerous that may be if continuing to drive with it like that. \n\nThanks in advance for any help on this matter.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-7-30 05:27:23 来自手机 | 显示全部楼层
1352321 发表于 2024-07-22 03:29:33 You’re driving a truck and you don’t know what the problem is??
","text":"dont put a person down for asking a question.would rather they ask someone and learn something right?","replyToPid":481274}
回复 支持 6 反对 1
发表于 2024-7-22 11:29:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"You’re driving a truck and you don’t know what the problem is??","replyToPid":0}
发表于 2024-7-17 07:38:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"that's right better get it fixed","replyToPid":0}
发表于 2024-8-1 01:50:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"I was going to get on here to tell him that his hub seal is leaking and to repair it asap but you guys got it covered. Lol later ✌🏼","replyToPid":0}
发表于 2024-7-18 06:04:04 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Fix immediately! \n\nHub seal(outside) or wheel seal(inside) has gone bad. Your hub oil is leaking out. The up to 34,000-lbs of force has less hub oil to reduce friction AND carry away the heat from friction. You will melt your hub if you don't get it repaired."}
发表于 2024-7-17 04:47:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Oil seal went bad. Repair immediately so it doesn’t create any more damage.","replyToPid":0}
发表于 2024-7-31 06:26:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"As soon as possible, otherwise the damage will be unbelievable","replyToPid":0}
发表于 2024-7-22 23:58:19 来自手机 | 显示全部楼层
","text":"most are flipflop put it in d wheel holders","replyToPid":481274}
发表于 2024-12-8 07:05:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"fyi.  ANYTIME you see oil leaking from anywhere on your rig and it's causing smoke...i would file that in the \"definitely not good\" category. drive on it at your own risk","replyToPid":0}
发表于 2024-8-9 00:27:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bad wheel seal","replyToPid":0}
发表于 2024-7-25 12:43:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"as others have mentioned, get it fixed ASAP. it's a seal leak and if not fixed promptly, it could cause a fire. DOT would also shut you down if they notice it costing you a road call.","replyToPid":0}
发表于 2024-7-27 06:53:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"What did you have to have repaired?","replyToPid":0}
发表于 2024-7-30 21:29:50 来自手机 | 显示全部楼层
42207 发表于 2024-07-29 21:27:23 dont put a person down for asking a question.would rather they ask someone and learn something right?
","text":"sounds like a blown wheel seal to me ...you'll smoke your bearings when it runs out of oil","replyToPid":481372}
GMT+8, 2026-4-18 07:02 , Processed in 0.161661 second(s), 24 queries .
