查看: 16|回复: 4
Truck stops
 楼主| 发表于 2024-7-12 06:51:13 来自手机 | 显示全部楼层 |阅读模式
{"text":"I am sick and tired of all the loves terrible showers. They don’t care about the truck driver all they care about. Is you buying their fuel for the past five days I’ve only had a trickle of water were you have to stand next to the wall to get any water on you, let alone get the soap off. loves has joined the ranks with  TA Petro flying J and pilot but at least with those ones all I need to do is bring Clorox and clean. At least I have water pressure..","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-7-18 08:11:23 来自手机 | 显示全部楼层
2460771 发表于 2024-07-16 07:12:17 Which particular Loves locations are you referring to? I am curious to know if it is a nationwide or regional issue.
","text":"I've had no problem with the showers at loves.....this is probably a 409 lb man crying because he can't fit or they don't have a chair every 2 foot so he can rest for 30 minutes and then go another 2 foot","replyToPid":481240}
回复 支持 6 反对 0
发表于 2024-7-16 15:12:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Which particular Loves locations are you referring to? I am curious to know if it is a nationwide or regional issue.","replyToPid":0}
发表于 2024-7-15 11:04:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Back in 2019 Loves had the best/ brand new showers","replyToPid":0}
发表于 2024-7-18 12:03:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"I prefer Pilot any day best option","replyToPid":0}
GMT+8, 2026-2-5 09:56 , Processed in 0.094306 second(s), 24 queries .
