查看: 28|回复: 13
How do we shift a automatic and where is the clutch I don’t find
 楼主| 发表于 2024-6-25 11:20:36 来自手机 | 显示全部楼层 |阅读模式
1万
发表于 2024-6-28 19:48:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"I think the question was \"where is the clutch\" ???\n 🤔 🤔 🤔\nI think the poster is still looking for it...\n😧😁😧","replyToPid":0}
发表于 2024-6-27 04:20:05 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Computer shifts the automatic transmission when it's programming says it should.\n\nYou CAN manually shift in an automatic. Usually a lever on the right side of the steering wheel(at least in a Freightliner or International)."}
发表于 2024-6-28 11:59:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Some trucks have a button at the end of the engine brake handle if you press it it’ll switch to manual or (performance mode) you don’t use a clutch pull it towards you to select a higher gear and push away to lower a gear, that being said it still won’t drive the same as a manual transmission.","replyToPid":0}
发表于 2024-6-26 01:11:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't care either way. But the drivers getting out of school with a automatic cdl is sad.","replyToPid":0}
发表于 2024-7-27 11:57:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm have no restriction but automatic is tougher when backing.","replyToPid":0}
发表于 2024-7-21 04:04:40 来自手机 | 显示全部楼层
403506 发表于 2024-06-25 17:11:28 I don't care either way. But the drivers getting out of school with a automatic cdl is sad.
","text":"That’s because pretty much all the fleets are running automatic trucks","replyToPid":481017}
发表于 2024-6-25 11:44:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Up yourself","replyToPid":0}
1万
发表于 2024-6-25 17:46:32 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"it's automatic...\n\nI prefer a manual transmission over a automatic transmission....\n 🙂 🇺🇸 👍"}
发表于 2024-6-26 03:53:22 来自手机 | 显示全部楼层
","text":"Semper Fi","replyToPid":481017}
发表于 2024-7-8 18:36:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"yeah,  that's an issue isn't it!?!?  🫢","replyToPid":0}
GMT+8, 2026-2-5 10:04 , Processed in 0.091013 second(s), 24 queries .
