查看: 90|回复: 20
Carbon Monoxide
 楼主| 发表于 2024-6-12 12:55:55 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hey yall new driver here,\nSo I have seen how some people have died while I sleeping in the incab. I know as long as there is no leaks or issues you are fine but there still is that slight possibility. Should I get a carbon monoxide alarm for extra security and if so is there any brands anyone recommends?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-6-12 20:23:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"nothing wrong with getting a carbon monoxide detector, but people you talking about died because they had cooking stoves in cabs, they were using gas for cooking and heating...something I would never do.","replyToPid":0}
回复 支持 5 反对 1
发表于 2024-6-14 16:55:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Kidde has lithium battery ones, lasts a number of years, not sure how well in a truck.   I have used  MSA Altair single gas detector, these are more industrial, small, can clip on your belt, expensive but battery lasts a long time as well.","replyToPid":0}
发表于 2024-8-6 09:59:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"I agree, but most exhaust leaks are noticeable audibly or visually. Your engine will be louder while running, or if you open the hood you can clearly see the ash or soot around the hoses. \n\nAnyhow, I am not a mechanic and I would never compromise my safety. I have a working CO and smoke alarm in my cab all the time. I bought it from Lowes and both cost round $60.","replyToPid":0}
发表于 2024-6-13 23:18:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Any plug in CO detector would work as long as you have an invertor.  I don't know if any CO detectors that work off battery or 12V DC.","replyToPid":0}
发表于 2024-8-5 14:12:26 来自手机 | 显示全部楼层
2457713 发表于 2024-06-12 12:23:39 nothing wrong with getting a carbon monoxide detector, but people you talking about died because they had cooking stoves in cabs, they were using gas for cooking and heating...something I would never do.
","text":"Umm, CM poisoning can occur due to an exhaust leak while idling.","replyToPid":480847}
发表于 2025-10-22 03:22:38 来自手机 | 显示全部楼层
811349 发表于 2024-08-05 06:12:26 Umm, CM poisoning can occur due to an exhaust leak while idling.
","text":"He wasn’t arguing it didn’t. He just stated information that was known to him.","replyToPid":481430}
发表于 2025-10-22 01:04:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bunch of crybabaies","replyToPid":0}
发表于 2025-10-21 23:39:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thermo King is great.","replyToPid":0}
发表于 2024-6-22 05:30:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ve been thinking more and more about getting one, there’s is times at some truck stops it gets heavy in the cab","replyToPid":0}
发表于 2025-10-21 21:46:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"I was about to say, whole reading the first sentence in your post, just get a detector if you’re concerned about the potential chance of carbon monoxide getting inside. It getting close to winter and all, and with temps floating around 40-58 in the evenings, just turn your truck off, and use bunk heater. That’s not actually a fix, if you do have a leak. \n\nIf you have a leak, you should NOT be driving your truck, that’s very dangerous even while driving. If there are any odd odors coming off into your cab, get it inspected asap.","replyToPid":0}
发表于 2024-6-16 04:19:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"So how are you liking it so far?","replyToPid":0}
发表于 2024-6-26 15:47:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nothing to worry about. I never heard or know anyone that died from CM. Be safe out there lady","replyToPid":0}
发表于 2024-8-7 10:54:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"I usually leave one of the top windows cracked a bit just in case …","replyToPid":0}
GMT+8, 2026-2-4 19:03 , Processed in 0.095907 second(s), 24 queries .
